(Done) [HOU-3155] IPR Different then Production Render
  • (Done) [HOU-3155] IPR Different then Production Render
    I updated to the latest nightly(vray_adv_52020_houdini18.5.759_3174d6f_220 16_install_windows from 29.03.2022).
    It seams like that there's a problem with the IPR Rendering, it's different to the Production Render. I made a quick sample: 3 boxes, give them a attribute, split them and apply materials to it. I use an MaterialBuilder to put all 3 Materials in it.
    This Worked with the following Build: vray_adv_52020_houdini18.5.759_a4fd1af_20621_insta ll_windows
    Is anyone else having this Bug?
    Or am I doing something wrong?
    Scene File:
    https://we.tl/t-jS8YG36tYv
    Cheers
    Tobias
    Hello tobiasroesli , I've reproduced and reported the issue. It is better to use different V-Ray Material Builders for different shaders instead of using different material outputs in one builder.
    Georgy Chakarov | QA
    www.chaosgroup.com
    georgy.chakarov@chaosgroup.com
      Hi chakarov ,
      ok, good to know, thanks
      Is there a solution for using the same Textures in different MaterialBuilder Networks?
      Like the Solution with NULL_OUT and Object Merge for SOP's
        Hey tobiasroesli ,
        You can use the Referenced Shader VOP and point it to the node you'd like to bring into a separate network.
        Best regards!
        gosho.genchev@chaosgroup.com
          Hello chakarov ,
          that's it, you just opened a whole new world, thanks
          Cheers!
            Hi chakarov ,
            I tested the Referenced Shader VOP and I was a little disappointed that the Null Node is not working.
            For me this would be a key element for this kind of workflow because you can plugin several inputs.
            If this would work, you could just do one Output Null for all information you want to use in other Networks. Now you have to do one RefShader per output.
            What do you think?
            Cheers
            Tobias
              Do you want reference shader to reference NULL VOP?
              andrei.izrantcev@chaos.com
              Support Request
                Hi bdancer ,
                would that not make sense?
                If you have a MaterialBuilder and in it you got a complex Network and you need to use 10 Outputs in other Material Builders for saving Memory if you are using GPU rendering or just because its the procedural way .
                In the post above you see how the Null lists all the inputs very handy but the refShader doesn't read it only the Vray Nodes.
                  It may.
                  Support Request
                    Hey tobiasroesli ,
                    Support for referencing Null VOPs is now included in the latest nightly build.
                    Hope that helps!
                      Hi Gosho.Genchev ,
                      thanks a lot, I will try it asap
                      Appreciate it very!!!
                      Cheers!
