VrayLightDome Override Alpha
  • VrayLightDome Override Alpha
    Hello!
    Just wanted to note that this option seems not be doing anything.
    If I check and lower the Alpha to 0 the dome light still renders with full alpha.
    And there's another thing that I can't manage to archive. I have a transparent object and a dome light, how can I make the dome invisible in the background but keep the visibility through the transparent objects? I can't find a way to do it.
    If I check Invisible in the dome light the dome is not visible through transparent objects.
    Maybe adding a Refract Contribution paramenter is the solution... just guessing...
    www.gaell.com
    You could disable "Affect Alpha" in Advanced group of Dome Light, this will render the DomeLight but the alpha will "cut" it.
    Georgy Chakarov | QA
    www.chaosgroup.com
    georgy.chakarov@chaosgroup.com
