It's been a while since I used Cryptomattes in v-ray Houdini and Nuke. V-ray seems to render the passes, but as soon as I drop down a Cryptomatte node in nuke 13 (the built-in crypto matte) I'm unable to pick the mattes. It just goes black. A trick or something obvious I'm missing? Thanks
Cryptomatte
Cryptomatte seems to work on my side.
Can you share some more info, Houdini,OS and V-Ray versions? Is it Solaris ? May be a hip file?
It's the output file name pattern, if you have "$AOV" tag in it V-Ray will save every channel in separate file The problem is that every cryptomatte layer is saved in a separate file and I think there is no working solution to combine them in a useful way. So you just need to remove $AOV tag from filename and V-Ray will save all the elements in a single file and the cryptomatte will work in nuke.
