Preset materials in vray library not rendering
  • Preset materials in vray library not rendering
    Hi everyone,
    I know this is such a basic question, but I haven't found any other threads or documentation to alleviate the issue.
    All I'm trying to do is render any type of material with a bitmap from a "Vray Image File Node". I've chosen a premade brick material as a test, which is assigned at the geometry level. Not really sure what I'm doing wrong.
    I looked through the log and it says the file has been loaded correctly...
    [22:30:06.185] Bitmap file "C:/Users/TC/Documents/V-Ray Material Library/assets/Bricks/Bricks_A_Bump_01_hires_lin_srgb.tx" loaded.
    [22:30:06.188] Bitmap file "C:/Users/TC/Documents/V-Ray Material Library/assets/Bricks/Bricks_A_Diff_01_hires_srgb.tx" loaded.
    Image provided for reference. Any help would be greatly appreciated.
    Version 19.0.455 for Houdini & Vray.
    You have UVs on your box? As I remember those material presets use UVs not tri-planar mapping, so UVs are necessary.
    Best,
    David.
    David Anastácio // Accenture Song - VFX
    https://www.accenture.com/us-en/serv...visual-effects
      Easy enough! Thank you for your help.
        Hello talisa_chhabra , david.anastacio is right, try to set any uvs and check if the problem still exist.
        Georgy Chakarov | QA
        www.chaosgroup.com
        georgy.chakarov@chaosgroup.com
