Camera variable in file path is not working
  • Camera variable in file path is not working
    Hi, camera variable in file path is not working. The image is saved without camera name. Can you please check? Thanks
    V-Ray for Houdini number:23914 hash:a62975a from 13 Apr 2022 19:15
    V-Ray Core 5.20.20 [18a43118] from 12 Apr 2022
    Works fine for me...
    What if you middle click on "File Path" - will it be expanded correctly?
    andrei.izrantcev@chaos.com
    Support Request
      Middle click return this
      "P:/Project/1233/HOU/render//obj/C002-01_TOP-01.exr"
      which seems strange with the double"//"?
        Why so? Camera path starts with "/" and you have one "/" in "render/".
        And what path do you have in the exported vrscene?
        In my case I see
        Code:
        img_file=interpolate(
            (1, "cam1.exr")
        img_dir=interpolate(
            (1, "c:/scenes/houdini/features/render_channels/render/obj/")
        which is correct.
        Support Request
          Correct.
          Actually the correct syntax I was looking for is `opname(chs("render_camera"))`
          Thx
