RenderFarm File Loading issue
  • RenderFarm File Loading issue
    HI All,
    We are switching from 3dsmax to Houdini recently.
    There is an issue that our render farm machines start rendering even some files are not loaded, leading to randomly missing models/textures.
    A little background of our setup:
    Workstations and render farm are using Houdini 19.0 and Vray 5
    The rendering management software is Deadline.
    We store models (mostly Alembic file) and textures (exr udim) on two separate local-network machines, and the network speed is not very fast.
    Vray for 3dsmax has no such problem at all.
    I would like to know if there is some kind of settings we can set to prevent the problem.
    Thank you for your time.
    edit 1:
    I take a look of Deadline logging. When the files are missing, there will be a warning message:
    V-Ray: Bitmap file "\\xxx/xxx/xxx.exr" failed to load: cannot open file:[LoadImageFile] 1: Failed to open file: no such file
    Is there anyway to stop the renderer if missing files, or to reload the file?
    So, is this location reachable from the render node?
    ROP -> Renderer -> Options -> Rendering -> Abort Rendering On Missing Asset
    No.
    andrei.izrantcev@chaos.com
    Support Request
      Yes, all the path are reachable. And I noticed that It's very likely to happen if too many machines are trying to render at the same time.
      Thank you, this might be helpful.
        After few tests, I can confirm texture missing doesn't count as missing asset.
          It should count. Are we talking UDIM or file names with tags/frame number?
          You could also try setting VRAY_UNC_TIMEOUT env. var. on your render nodes to some higher value then 5000 (timeout in milliseconds).
          Support Request
            Yes you're right, it's UDIM textures with tags. And only one or few frames of UDIM missing when happening.
            OK, I will try it.
              We are just experiencing this issue now.
              Exact same symptoms as OP.
                Unfortunately we're not able to solve the problem, I hope this thread can raise the awareness for the developers.
                For those who might not understand, I attached this video to illustrate the issue better.
                18 frames of UDIM projected on a plane.
                  For us the environment variable seems to have fixed the issue. I set it to 10 sec instead of 5.
                  Since doing that we haven't seen the issue again.
                  I don't know why it would be timing out - our NAS is usually extremely fast. Especially cached files are served up in milliseconds.
                    Thanks for posting that!
                    I'll definitely check again.
                      Just another data point on this issue.
                      Checking on "Low priority thread" also seems to solve this problem.
                        bdancer could this help on linux as well? We got the sporadic error where textures randomly doesnt load for some objects in the scenes on random frames
                          No, timeout is Windows only.
                          Support Request
                            May I know if there's any update about this issues? This really affect the the production speed and i am thinking if Vray is not ready for proper VFX production....
                              Hey juleslin ,
                              Could you please take a look at the info in the Red warning box here: https://docs.chaos.com/display/VRAYHOUDINI/IPR+Tab
                              Hopefully it's the same issue.
                              Best regards!
                              gosho.genchev@chaosgroup.com
