black rendered frames
  • black rendered frames
    Hi, I am using following version: vray_adv_52024_houdini19.5.303_cf37d70_22126.bin
    Viewport rendering works fine but when I render via USD render all I get is black frames. I tried to update but subsequent updates are completely bugged, viewport render ignores all the materials and throws following error:
    2022/Aug/15|15:39:38] [error] V-Ray creation error: Instantiation error.
    I understand it is nightly build but I would really appreciate if you look into this issue, I am very keen to switch from redshift but somewhat lagged development (no stable version for h19.5) prevents me from doing that.
    Having said that I don't usually jump on new version of Houdini right away but with solaris being so immature each new Houdini sorts a lot of things out.
    There is a separate section for Solaris/USD https://forums.chaos.com/forum/v-ray...ni-solaris-usd
    > "V-Ray creation error: Instantiation error."
    I've just tried it and it works fine for me, at least on Windows. What's your OS?
    Anything could cause this error, we'll need a hip file to investigate this.
    Also, we haven't yet announced 19.5 support, we are still testing it.
    What does "subsequent updates" means? Newer nightlies?
    [UPDATE]
    I see some linkage issues, will fix.
    andrei.izrantcev@chaos.com
    Support Request
      I am sorry I forgot to mention, I am running Fedora 35.
      I meant newer nightlies, all after 20220812.
      I am happy to post hipfile, is there any way to do is so it is not public ?
        No need for it already, tnx. Next nightly should work better.
        Support Request
          Thank you, much appreciated.
