(Fixed) [HOU-3307] DOF wrong distance
  • (Fixed) [HOU-3307] DOF wrong distance
    Hello,
    I updated from the stable Vray 5.2 from August 3th version to the newset nightly (V-Ray for Houdini number:22132 hash:4344ab5 from 20 Aug 2022 01:37
    V-Ray Core 5.20.24 [493f4a2c] from 15 Aug 2022) and it looks like that there are some problems with the distance of the focus point when working with the VrayPhysicalCamera.
    Roughly I would say that the Focus Distance is multiplied with something like 10.
    I use a Constraint Network with followpath and lookat.
    here's the scene:
    https://we.tl/t-ADDCT4HGcl
    Cheers
    Tobias
    Did you scale the camera or parentent it under a node that is scaled? I hab issues with that before.
      I used a constraint network and in it I used followpath and lookat. The thing is that the stable version from 3th of August was working and after the switch to the new nightly it was wrong.
        Hey tobiasroesli ,
        I confirm there is an issue that we managed to hit with our internal tests as well - the developers are looking for a fix. I'll update you as soon as the problem is resolved.
        Best regards!
        gosho.genchev@chaosgroup.com
          Hello Gosho.Genchev ,
          thanks for looking into it, appreciate it
          Cheers!
            Hey tobiasroesli ,
            The issue is resolved on my end with today's nightly builds. Could you please check if that fixes the problem for you as well?
            Best regards!
              Hey Gosho.Genchev ,
              I can approve in Nightly (V-Ray for Houdini number:22135 hash:38a13b9 from 23 Aug 2022 01:31
              V-Ray Core 5.20.24 [493f4a2c] from 15 Aug 2022) its working.
              Thanks for the quick fix
              Cheers!
