(Fixed) [HOU-3503] VRayLight option for projecting texture with a spotlight
  • (Fixed) [HOU-3503] VRayLight option for projecting texture with a spotlight
    I am trying to emulate the lighting characteristics of the caustic reflections of a disco ball.
    For this I want to project a texture through a spotlight. (The last time I have done this is 16 years ago ... maya software rendering)
    But the vray spot light does no have a texture slot as the vray light rectangle has.
    I can project a texture through an vray light rectangle and set the directionality to 1 to get it sharp. But it does not have the characteristic of a spot light.
    I also tried to make the size of the are light as small as I could, and to reduce the directionality to 0.5 ish. But this results in a very noisy and still not sharp light pattern.
    Help is apreciated
    Cheers
    Christian
    Sorry for late reply, you could use "Emission Color" in Textures group of SpotLight UI.
    Georgy Chakarov | QA
    www.chaosgroup.com
    georgy.chakarov@chaosgroup.com
Name:	Screenshot 2022-10-24 075341.png
      THX for the Reply Chakarov. I tried it, but the projected image repeats. I do not seem to have control over the "uv space" of the projecting spotlight.
        The texture should be loaded in mat network as V-Ray ImageFile VOP, and than the path to this vop should be provided to spotlight "Emission Color". This way you will have all the texture controls available in V-Ray ImageFile.
        www.chaosgroup.com
          Yes, that totally works. Thanks Chakarov !!!
            Hi, im having an issue instancing spotlights that have emission color, like a gradient map plugged in. As soon as i instance this spotlight onto points using s@instance attribute, the lights dont show up anymore in render.
            https://www.dropbox.com/t/W5giCKu5lGKWhkMw
            link above is simple hip file of the problem. working on live job that needs this working, so appreciate any help anyone has.
            cheers
            J
            Atomic14
              Hey the_one_j ,
              We've added support for the Emission color texture on instanced lights with the nightly builds from Nov 10, 2022.
              Best regards!
              gosho.genchev@chaosgroup.com
