Trying to install v6 on Apple Silicon. I've swapped the path in the .json to
{ "INSTALL_ROOT" : "/Applications/ChaosGroup/V-Ray/Houdini_19.5.435/vfh_home" },
and put both vray_for_houdini_py39.json vray_for_houdini_py37.json in my packages directory (is that right?). I get a V-Ray menu in 19.5.435 (apple silicon) but in the About V-Ray I see:
V-Ray Python 3.9 module is not found!
and if I try to drop down for instance a v-ray light I get:
Traceback (most recent call last):
File "object_VRayNodeLightDome", line 1, in <module>
File "/Applications/Houdini/Houdini19.5.435/Frameworks/Houdini.framework/Versions/19.5/Resources/houdini/python3.9libs/toolutils.py", line 1432, in new_func
return function(*args, **kwargs)
File "/Applications/Houdini/Houdini19.5.435/Frameworks/Houdini.framework/Versions/19.5/Resources/houdini/python3.9libs/objecttoolutils.py", line 494, in genericTool
node = toolutils.genericTool(scriptargs, nodetypename, nodename,
File "/Applications/Houdini/Houdini19.5.435/Frameworks/Houdini.framework/Versions/19.5/Resources/houdini/python3.9libs/toolutils.py", line 1551, in genericTool
(child, newnode) = createNodeInContainer(container, nodetypecategory,
File "/Applications/Houdini/Houdini19.5.435/Frameworks/Houdini.framework/Versions/19.5/Resources/houdini/python3.9libs/toolutils.py", line 1410, in createNodeInContainer
newnode = _mapSubnetToNode(parent, nodetypecategory, container.childTypeCategory()).createNode(nodetype name, nodename,
File "/Applications/Houdini/Houdini19.5.435/Frameworks/Houdini.framework/Versions/19.5/Resources/houdini/python3.9libs/houpythonportion/ui.py", line 1119, in decorator
return func(*args, **kwargs)
File "/Applications/Houdini/Houdini19.5.435/Frameworks/Houdini.framework/Versions/19.5/Resources/houdini/python3.9libs/hou.py", line 14556, in createNode
return _hou.Node_createNode(self, node_type_name, node_name, run_init_scripts, load_contents, exact_type_name, force_valid_node_name)
hou.OperationFailed: The attempted operation failed.
Invalid node type name
