[HOU-2308] Render problem - output node priority?
  • [HOU-2308] Render problem - output node priority?
    Hi there, I was wondering if you guys could make a change to the way vray currently renders the Houdini scene, I've just had a big problem on a job I've been rendering because vray doesn't use the output node when rendering it uses the display flag, so when I went to the object level I though all my components would be rendered because they're all being displayed, they did not render.
    It would be really useful to be able to change what takes priority, but with the output node to have priority by default.
    I've uploaded an attachment to illustrate what I mean.
    Should work in the next nightly.
    andrei.izrantcev@chaos.com
    Support Request
      That's great, thanks so much.
      I also just want to add that I've always been really impressed with the Vray development and support team and your attention to users, it's the best customer service experience I've ever had.
        Thank you!
        Support Request
