Cant submit job to deadline from Houdini, Submission failed! Check console output!
  • Cant submit job to deadline from Houdini, Submission failed! Check console output!
    I'm trying to submit a Render at Deadline "Version: 10.2.0.10" from Houdini 19.5.435 Py3.9 / V-Ray 5.00.21 and I'm getting this error "Submission failed! Check console output!",
    also, I can't find the console to see the error.
    I didn't have any problems with the submission from Houdini 19.0.455 with V-Ray 5.20.02 at the same deadline.
    any suggestion to debug or a solution I would appreciate it.
    Thank you
    Nikos
    You may set HOUDINI_TEXT_CONSOLE=1 (or HOUDINI_WINDOW_CONSOLE=1) in the houdini.env, it'll open console window you may check for some output.
    andrei.izrantcev@chaos.com
    Support Request
      Thank you for the quick response!!
      I got this error back.
      Is there I can do?
      [2023/Mar/31|13:10:13] VFH | Info| * Build hash:20a9711 from 12 Dec 2022 21:57
      [2023/Mar/31|13:11:37] VFH | Error| * V-Ray Deadline: Grabbing submitter info...
      [2023/Mar/31|13:11:51] VFH | Error| *
      [2023/Mar/31|13:11:51] VFH | Error| * Deadline version: v10.2.0.10 Release (3b87216c7)​​
        This is wrong message level (it's not an error) and it was fixed in some latest nightlies.
        But the submission error from your first post is smth else.
        Will there be any errors if you'll press submit?
        Support Request
          These are the things that I get.
          I cant find something else.
          I'm open to suggestions
            We'll check this on our side and get back to you asap.
            Support Request
              Thank's a lot!
                Is it possible for you to try some more recent build, some nightly or stable nightly?
                Support Request
                  Yes, I did as u suggested and it submitted fine!
                  The version that I test is vray_adv_60021_houdini19.5.435_ac0293f_22354 (1/April/2023)
                  Thank you!
