(Fixed) [HOU-3803] screenwindow size != 1 and motionblur change resolution
  • (Fixed) [HOU-3803] screenwindow size != 1 and motionblur change resolution
    When using a screen window size !=1 and turn on motionblur, the resolution of the render changes in an unexpected ways. Have a look at the attached scene. It appears that this is a rather new issue.
    if you turn off mb OR set the screen window size to 1, the resolution returns to expected values.
    Hey ronald_a ,
    The developers are looking into it, I'll ping you with any updates.
    Best regards!
    gosho.genchev@chaosgroup.com
      Hey ronald_a ,
      Happy to message that this should be OK now, using the latest stable builds.
      Best regards!
        Hi Gosho.Genchev, it seems, the latest stable 20230515 folder is empty and builds from 20230506 don't seem to have the fix. I did test nightlies which seem to have the fix but would prefer to have a stable build. Probably just a mixup...
