(Resolved) [HOU-3921] Bercon UV Variance by attribute
  • (Resolved) [HOU-3921] Bercon UV Variance by attribute
    Hi There, I was wondering if you could add the ability to use a user attribute for V-Ray UVWGenBercon variance mode. I work a lot with bercon noise and wood and applying a random offset/rotation/scale is a nightmare as I have to manually split all the geometry into multiple geo networks which can take a very long time depending on the complexity of the model.
    I'd really like to be able to use a user attribute such as class/name/id/Cd as the seed to change the variation on different geometry islands.
    please let me know if this is a possibility.
    Cheers.
    Hey chadstevens ,
    I'd like to quickly clarify if your inquiry is regarding (1) the Variance Offset/Size/Angle parameters or (2) the Seed parameter?
    Best regards!
    gosho.genchev@chaosgroup.com
      Hi Gosho, thanks for getting back to me.
      I'd like it to affect the Variance Offset/Size/Angle parameters.
      Cheers.
        Gosho.Genchev Is there any chance this will be implemented?
        Cheers.
          Hey chadstevens ,
          We've added the request in the tracker and we'll try to find a solution.
          Best regards!
            Hi Gosho.Genchev I just wanted to say thank you, I see there is now a variance parameter on the Bercon UV and it seems to be working great, thank you so much for implementing this, it's going to make my life much easier
