houdini 19.5.569 vray 6.1 cgru render error
[2023/Oct/8|00:02:39] VFH | Info| V-Ray: Progressive rendering finished: specified noise level reached
[2023/Oct/8|00:02:39] VFH | Info| V-Ray: Sampling level reached: 16.58 subdivs (328 passes)
[2023/Oct/8|00:02:39] VFH | Info| V-Ray: Number of raycasts: 37459450 (40.65 per pixel)
[2023/Oct/8|00:02:39] VFH | Info| V-Ray: Camera rays: 8566551 (9.30 per pixel)
[2023/Oct/8|00:02:39] VFH | Info| V-Ray: Shadow rays: 8381075 (9.09 per pixel)
[2023/Oct/8|00:02:39] VFH | Info| V-Ray: GI rays: 21139000 (22.94 per pixel)
[2023/Oct/8|00:02:39] VFH | Info| V-Ray: Reflection rays: 0 (0.00 per pixel)
[2023/Oct/8|00:02:39] VFH | Info| V-Ray: Refraction rays: 0 (0.00 per pixel)
[2023/Oct/8|00:02:39] VFH | Info| V-Ray: Unshaded rays: 0 (0.00 per pixel)
[2023/Oct/8|00:02:39] VFH | Info| V-Ray: Peak memory for frame 5: 517.71 MiB collected for 22 categories
[2023/Oct/8|00:02:39] VFH | Info| V-Ray: Peak memory for "Bitmap": 0 B
[2023/Oct/8|00:02:39] VFH | Info| V-Ray: Peak memory for "Bucket image sampler": 0 B
[2023/Oct/8|00:02:39] VFH | Info| V-Ray: Peak memory for "Dynamic displaced geometry": 0 B
[2023/Oct/8|00:02:39] VFH | Info| V-Ray: Peak memory for "Dynamic geometry": < 1 MiB
[2023/Oct/8|00:02:39] VFH | Info| V-Ray: Peak memory for "Dynamic moving displaced geometry": 0 B
[2023/Oct/8|00:02:39] VFH | Info| V-Ray: Peak memory for "Dynamic moving geometry": 0 B
[2023/Oct/8|00:02:39] VFH | Info| V-Ray: Peak memory for "GI": 3.34 MiB
[2023/Oct/8|00:02:39] VFH | Info| V-Ray: Peak memory for "Lights": < 1 MiB
[2023/Oct/8|00:02:39] VFH | Info| V-Ray: Peak memory for "Misc.": 28.91 MiB
[2023/Oct/8|00:02:39] VFH | Info| V-Ray: Peak memory for "Misc. displaced geometry": 0 B
[2023/Oct/8|00:02:39] VFH | Info| V-Ray: Peak memory for "Misc. geometry": < 1 MiB
[2023/Oct/8|00:02:39] VFH | Info| V-Ray: Peak memory for "Misc. moving displaced geometry": 0 B
[2023/Oct/8|00:02:39] VFH | Info| V-Ray: Peak memory for "Misc. moving geometry": 0 B
[2023/Oct/8|00:02:39] VFH | Info| V-Ray: Peak memory for "Progressive image sampler": 461.29 MiB
[2023/Oct/8|00:02:39] VFH | Info| V-Ray: Peak memory for "Static displaced geometry": 0 B
[2023/Oct/8|00:02:39] VFH | Info| V-Ray: Peak memory for "Static geometry": < 1 MiB
[2023/Oct/8|00:02:39] VFH | Info| V-Ray: Peak memory for "Static hair": 0 B
[2023/Oct/8|00:02:39] VFH | Info| V-Ray: Peak memory for "Static moving displaced geometry": 0 B
[2023/Oct/8|00:02:39] VFH | Info| V-Ray: Peak memory for "Static moving geometry": 0 B
[2023/Oct/8|00:02:39] VFH | Info| V-Ray: Peak memory for "Static moving hair": 0 B
[2023/Oct/8|00:02:39] VFH | Info| V-Ray: Peak memory for "Tiled bitmap": 0 B
[2023/Oct/8|00:02:39] VFH | Info| V-Ray: Peak memory for "VFB": 24.13 MiB
[2023/Oct/8|00:02:39] VFH | Info| V-Ray: Light cache utilization: 68.64%
[2023/Oct/8|00:02:39] VFH | Info| V-Ray: Number of light evaluations: 8872910 (9.63 per pixel)
[2023/Oct/8|00:02:39] VFH | Info| V-Ray: Maximum memory usage for resman: 0.00 MB
[2023/Oct/8|00:02:39] VFH | Info| V-Ray: Number of intersectable primitives: 692
[2023/Oct/8|00:02:39] VFH | Info| V-Ray: SD triangles: 692
[2023/Oct/8|00:02:39] VFH | Info| V-Ray: MB triangles: 0
[2023/Oct/8|00:02:39] VFH | Info| V-Ray: Static primitives: 0
[2023/Oct/8|00:02:39] VFH | Info| V-Ray: Moving primitives: 0
[2023/Oct/8|00:02:39] VFH | Info| V-Ray: Infinite primitives: 0
[2023/Oct/8|00:02:39] VFH | Info| V-Ray: Static hair segments: 0
[2023/Oct/8|00:02:39] VFH | Info| V-Ray: Moving hair segments: 0
[2023/Oct/8|00:02:39] VFH | Info| V-Ray: Successfully written image file "/run/media/linuxbug/Raid/project/test/render/test/testVray_05.0005.exr"
frame 1-5[linuxbug]:
[2023/Oct/8|00:02:39] VFH | Info| V-Ray: Maximum memory usage for texman: 0.00 MB
[2023/Oct/8|00:02:39] VFH | Info| V-Ray: Maximum memory usage for attributes: 0.00 MB
48161: Fatal error: Segmentation fault (sent by pid -459540730)
/opt/cgru/software_setup/bin/hrender_af: 行 5: 48161 段错误 (核心已转储)hython $HOUDINI_CGRU_PATH/hrender_af.py "$@"
when i use vray 6.0 work fine
use vray 6.1 cant end task ,got Fatal error: Segmentation fault
is vray 6.1 bugs
please help
thanks very much
is vray 6.1 bugs
please help
thanks very much
