Houdini Tri Planer Rest Issue Cpu and GPU
  • Houdini Tri Planer Rest Issue Cpu and GPU
    I have looked and haven't found a fix. I cannot get the textures to stick to the geo as expected with the tri planer. Not sure if its an issue with my setup for a Vray issue.
    Any help or direction would be awesome,
    Thanks​​​​​​​​
ID:	1195047 Click image for larger version
    Hi mike_jag,
    You've added rest position to you mesh, now you just need to tell the tri-planar to use it.
    You need to do 1 of 2 things here
    - Set the rest position in the object properties (setting the reference coordinates of the object with the V-Ray object properties).
    - Or just plug in a "userColor" node with the rest into your tri-planar map.
    Make sure you use both rest and rest normals with the tri-planar mapping for the best result.
    Best,
    David.
    David Anastácio // Accenture Song - VFX
    https://www.accenture.com/us-en/serv...visual-effects
      This is the preferred way, we'll remove "rest position in the object properties" for the next major update.
      andrei.izrantcev@chaos.com
      Support Request
        Got it, Thanks for the info. Ran into another issue It seems to work as expected under CPU but not Cuda with RBDs
ID:	1195142 Click image for larger version
