Hi there...
i saw this was an issue in 2022 already so i highjacked the title.
The problem is, materials are not assigned anymore with on packed Alembics. We used to export Alembic files from Houdini, import it back and then paste the material path into "Forced Materials" in the Objects tab of the Vray render node.
It used to work with a pervious version of Vray though i can't remember which one it was. We tried it with the latest stable version "Build 6.10.0" and it doesn't work there either.
A test file is attached.
Would be awesome if you could look into it, that feature is desperately needed
