Issue adding LPE to render elements
  • Issue adding LPE to render elements
    Hi, when rendering after adding a couple of LPE's to my render elements, I get this error message in the logs : "Warning : Unable to add LPE channel. Maximum number of light select elements reached." The warning is quite clear, however I haven't found where to increase said number of allowed light select elements. I very much doubt that it's a software limitation, as I just have 1 light mix containing 23 lights and 2 light select, each containing 2 lights. The issue could potentially be that one of my light select is containing a light that's being instanced across the scene?
    Hello luan_simonin Thank you for contacting us! The maximum number of individual Light Selects is 64 (including Environment and Self Illumination).
    It would be very useful if you could share the scene with us so we can investigate further. Please, go to V-Ray > Pack Scene and send us the files. You can do this here or by Submitting a Request to our system: https://support.chaos.com/hc/en-us/requests/new
