Hi all - trying to figure out how to get accurate motion blur across long shutter times, no matter what combination of settings we use it seems that V-Ray will only sample the velocity of the specific frame that is being rendered. Images attached showcasing this. If an objects is moving along a curved path we should be able to get accurate curved motion blur, not just a longer motion trail on that specific vector for that frame. Anyone got a solution?
Motion blur along curved paths with longer shutter times / high speeds
Have you tried increasing "Num. samples" after adding V-Ray object properties to the object?
It'll be easier to help if you could attach (or send to the email in my signature) the .hip file.
HI frame48 , seems to work fine in Houdini 20.0.590 and latest nightly of V-Ray 6.2 . What is your OS, Houdini and V-Ray versions?
This could probably be improved, but as a workaround you could set "No Velocity Blur" and use geometry samples directly.
Originally posted by bdancer View PostThis could probably be improved, but as a workaround you could set "No Velocity Blur" and use geometry samples directly.
> Could you provide a little more context on the no velocity blur approach you're mentioning?
Just set "Geometry Velocity Blur" to "No Velocity Blur", this way only animated point samples will be used.
