(open)[HOU-4182] save cryptomatte separately not working
  • (open)[HOU-4182] save cryptomatte separately not working
    the default path, .${AOV}.$F4.exr , won't save cryptomatte as one image, even when "save cryptomatte separately " checked, instead , you get ".cryptomatte.0001.exr",".cryptomatte00.0001.e xr", ".cryptomatte01.0001.exr",".cryptomatte02.0001 .exr ", the expected behaviour should be:
    when "save cryptomatte separately " checked, you get one ".cryptomatte.0001.exr", then in AE , it can be used with the cryptomatte effect.
    Hi len_xie , this seems to work only for .vrimg files. I'll log it to our system. Thanks for your feedback.
    Georgy Chakarov | QA
    www.chaosgroup.com
    georgy.chakarov@chaosgroup.com
      Hi again len_xie , removing the AOV tag in the file name will write the cryptomatte file as it should. Is this solution work for you?
      www.chaosgroup.com
        chakarov,hi , I tried that,but I need other aovs to be seperated,AE is not eficient when image size is huge and combined, can we get seperated one cryptomatte file along with other aovs?
