Do we have a memory leak or??
  • Do we have a memory leak or??
    So I am trying to render a set of frames and it will crash with a (700) error which from what I understand this may be a memory issue. I have occ turned on atm
    This is a pretty big sim using RTX to render by the way
    Houdini 20.0.590
    Vray 2.2
    Frame 1
    [11:12:29.326] Peak memory for "Misc.": 9.72 GiB
    Frame 16
    [11:26:04.663] Peak memory for "Misc.": 15.30 GiB
    I did run about 100 frames last night and peak memory was like 100gig​
    More info
    Could not allocate 6990500 bytes of GPU memory
    30636: Fatal error: Segmentation fault
    FromVFB Below
    [VUtils::VOptix::OptixPipelineWrapper::launch] 7900: OptiX error encountered in vray_optix7.cpp[319]. Error Code 7900
    [14:58:07.330] Error : [VUtils::VOptix::OptixPipelineWrapper::launch] 7900: OptiX error encountered in vray_optix7.cpp[319]. Error Code 7900
    [14:58:07.332] Error : C:\CI\cgrepo\vraysdk\samples\vray_plugins\rt_priva te\rt_opencl_(348 : CUDA error 700​
      Dear mike_jag, hello.
      Thank you for contacting us.
      Please share with us the exact V-Ray version used (V-Ray > About V-Ray > Copy to Clipboard and paste here).
      In addition please confirm also the installed GPU driver version. The recommended one could be found on this official page: https://www.chaos.com/vray-gpu
      We have encountered something similar in other V-Ray integrations, but without the exact V-Ray version is hard to match.
      Waiting for your answer.
      TS
      Tsvetomira Girginova | chaos.com
      3D Support | contact us
        Here is the info, Sorry for the delay
        This is happening on 3 different systems by the way. All but one have the recommended driver with the same version of Vray as well as Houdini.
        V-Ray for Houdini hash:82c1b12 from 19 Feb 2024 11:02
        V-Ray Core 6.20.05 [31923cf8] from 17 Feb 2024​
          Thank you for the details.
          Please try rendering the same scene with our latest stable builds, available here: https://nightlies.chaos.com/main#/vr...e/6.2/20240801
          Certain improvements are implemented there.
          If you are still experiencing this, please provide us with a test scene to perform actions in our environment with it.
          Thanks in advance.
            Thank you, I will try that today. Hopefully, this will fix the issue
