VRay Baker projected normal map issue
  • VRay Baker projected normal map issue
    Hello,
    We would like to use vray baker to create projected normal maps (highpoly to lowpoly). The aim is to use the normal maps for real-time PBR shader. We encountered a problem that we couldn't solve. Here is an overview of the problem (shown in Blender):
    In the vray bump normal maps, the tessellation of the low poly object stands out. In comparison, the LabsMapsBaker from sidefx. We have found that if the lowpoly does not contain any normals, the normal map is not displayed correctly in the pbr shader. As soon as a normal node is assigned to lowpoly, the normal output looks correct in LabsMapsBaker (top right image).
    In comparison, in VRay Baker it doesn't seem to make a difference whether the normals node is activated or not - the output looks the same in both cases.​
    Here is the houdini example setup:
    Click image for larger version  Name:	thumb_88786.jpg Views:	0 Size:	4.8 KB ID:	1224811
    The baking settings are all default​.If needed I can upload an example project.
    I would be very grateful for any advice or ideas.
    Best regards
    Mario​
    Hello daa , can you share the hip file?
    Georgy Chakarov | QA
    www.chaosgroup.com
    georgy.chakarov@chaosgroup.com
      Sure, here is the file attached.
        Hello, I was able to fix the problem. The problem was that the polygons on the flat surface were not really flat.​
        www.chaosgroup.com
          Thanks for your answer. I checked your solution: Flattening the surface using a treshhold is certainly a solution in this case - but I'm looking for a solution that also works with complex meshes without manual work steps.
          With the Labs Mesh Bakers I can achieve a clean result as described above without changing the geometry - provided there is a normal node. However, I cannot export the VRay Materials bump maps via this baker.
          Here is an example between Labs Baker and VRay Baker with a more complex mesh.​
            Hi again daa , you can try set the baker Normals to "Geometry"
            www.chaosgroup.com
              Hi chakarov,
              Thanks for your continued help! I tried your tip using the simple example above. Unfortunately, this does not solve the problem (see comparison Labs Maps Baker vs. VRay Baker).
              In the NormalMap you can also see clear differences at the corresponding points (I increased the contrast a little so that you can see it better). While the normal map from Labs Maps Baker initially looks rather flawed, it produces a (relatively) clean result on the mesh. In the VRay Normal Map, however, the irregularities are not noticeable - but when applied to the mesh it does not look planar.
              I would be very happy to receive any further ideas or tips.
