[HOU-4641](fixed)VRay IPR is restting my settings when using takes in Houdini
  • [HOU-4641](fixed)VRay IPR is restting my settings when using takes in Houdini
    The RE line says it all. when I fire up IPR and make a bunch of changes in my houdini file with a take active, as soon as I close the IPR or shut it down, all the changes I made get reverted back to what they were!!
    Anyone else have this issue? Does VRay not work with the take system?
    Thanks.
    Best, Christian
    It does work, but this has been a bug for a while and it's pretty annoying.
    If I remember correctly it only reverts back once you stop rendering, so I used to just save my file before I cancelled the render.
      Hi pixeldrone We have it logged in our system [HOU-4641] and will be looking into it further.
        ok, thank you. even if you have a nightly build or something with the fix I will take that, it's pretty inconvenient currently. Thanks for looking into this.
        Best, Christian
          Hello pixeldrone , the problem is fixed in latest nightly build.
          Georgy Chakarov | QA
          www.chaosgroup.com
          georgy.chakarov@chaosgroup.com
