[HOU-4680] Cryptomatte and DR not working correct
  • [HOU-4680] Cryptomatte and DR not working correct
    it seams that if you're using "Per Attribute Value" Cryptomattes the slave render buckets in DR Mode don't render correctly.
    Same behaviour in CPU, CUDA and RTX
    I use Houdini 20.0.896 and
    V-Ray for Houdini number:22872 hash:426ce75 from 07 Feb 2025 05:31
    V-Ray Core 6.20.25 [7409b9be] from 19 Jan 2025​
    Hey tobiasroesli ,
    Thank you for the heads up! Indeed the behavior is reproducible on my end as well.
    I've logged a ticket under HOU-4680. This may take a while to resolve as we are in the process of overhauling the V-Ray distributed rendering backend with a new implementation.
    Best regards!
    gosho.genchev@chaosgroup.com
      Hello Gosho.Genchev,
      glad to help and improve vray
      Cheers!
