frame buffer
  • frame buffer
    When rendering the final image is there a way to get it visualized. For example in the viewport and image viewer(space+5) we always see the ipr. I want to set the bucket instead of progressive for example and do a render in the scene, how do i go about doing that?
    http://goodbyekansasstudios.com/
    I've wondered this too. With Houdini 19 and Karma things are pretty good, because you can just render to Mplay, and setting aside Karma's progressive/bucket behavior, it's pretty familiar to the old Mantra/Mplay relationship. VRay5 has one of the nicest frame buffers out there, so it's a shame that we can't use it in Solaris. Is there any way this can be supported going forward? The IPR stuff is great for look-dev, but when you get down to the business of dialing in renders you really need a proper framebuffer.
      With husk?
      > I want to set the bucket instead of progressive for example and do a render in the scene.
      With husk? Or in viewport?
      andrei.izrantcev@chaos.com
      Support Request
        >With husk?
        no in the vieport. Sorry if im being vague. Im not 100% sure if i want the vray frame buffer back or i want the image viewer in houdini to behave like it
        in the viewport. Right now if i put vray to render bucket there is no way for me to be able to see it. I only have ipr in the viewport (or i think it is)
          Hi!
          We are also having trouble with this. In the USD render rop, the "Render to MPlay" button does not seem to be working when using vray.
          It brings up an MPlay window but the image never appears, it just stays black.
          When using Karma, it works as expected.
          This is using V-Ray for Houdini number:22437 hash:e9a44aa from 03 Mar 2022 04:57 V-Ray Core 5.20.20 [184660f8] from 24 Feb 2022 in Houdini 19.0.531 on windows 10
            vintrvidar
            1. "Render to MPlay" has nothing to do with VFB.
            2. In Solaris V-Ray is a Hydra delegate, it doesn't know anything about MPlay or however delegate is going to be used by the USD Hydra API. All it does is fills render buffer with the image data.
            3. It seems to work for me.
            Support Request
              Thank you.
              I think MPlay is enough for our purpose. We just want some way of seeing the progress of the render.
              Interesting to hear that rendering to MPlay works on your end. I will have to investigate why we are having trouble then.
              Do you have any pointers to what could be going wrong? I don't think there's anything unusual in our setup and the problem seems quite opaque at the moment, since there is no output.
              Is there a log or something we could look at to figure out the issue?
                Everything is printed to the stdout. Use HOUDINI_TEXT_CONSOLE to enable console window.
                Support Request
                  Anyway, it won't render progressively, I'll check what could be done.
                  Support Request
                    MPlay will show render progress in the next nightly.
                    However nothing will be shown if render is finished before MPlay is loaded. I have no control over it.
                    Support Request
                      Wow, thanks for the quick fix!
                      It does indeed work today, the buckets update in MPlay as the render progresses.
                        Cool! works for me too. Is it possible to hook up the focus rendering. When left clicking with mouse it focus the bucket or the progressive samples around that point.
                          If you have seen smth like that in V-Ray for 3dsmax or Maya then yes; no - otherwise.
                          Support Request
                            Cool, yes both should have it, this is from maya docs.
                            https://docs.chaos.com/display/VMAYA...y+Frame+Buffer
                            • #15
                              Hydra render buffer is not VFB unfortunately.
                              Support Request
