viewport settings and acescg primaries
  • viewport settings and acescg primaries
    so i realized i cant control the acescg primaries when using the viewport setting. Dont know whats the best way to solve this so we came up with 3 ideas. I think i would preferef the first one if that would be possible to do.
    1. pickup the rendering working space based on the ocio file. maybe roles rendering would be a solution
    Click image for larger version  Name:	ocio_vray_default.png Views:	0 Size:	25.1 KB ID:	1139164
    2. Make it be controlled by an envrionment variable so we can set it on startup
    3. add it to the viewport setting so it can be controlled manually from there ​​​
    http://goodbyekansasstudios.com/
    Hey Alexis,
    What exactly do you mean when you say you can't control them? Are you talking about the "Correction Toolbar" under the viewport?
    Best regards!
    gosho.genchev@chaosgroup.com
      Sorry, i meant the internal acescg.
      Regards Alexis
