Motion Blur Setting Disappeared
  • Motion Blur Setting Disappeared
    Hi
    Using the nightly 22121, it seems that the motion blur settings: Duration and Interval Center, disappeared from the Render Settings node, is there any specific reason for this change?
    Thanks,
    -Marvin
    Marvin Chrastek
    Lighting Lead @ Ghost VFX
    The motionblur is instead set on the shutter on the camera, this way it makes it both compatible with the other renderers like karma but also makes sure hydra and vray sample the same data. We had some issues when shutter and motionblur settings mismatched which made the geometry break.
    Regards Alexis
    http://goodbyekansasstudios.com/
      As Alexis wrote, yes, there seems no Interval Center in USD (and is always 0) that's why it's hidden, duration is controlled by camera's shutter settings.
      andrei.izrantcev@chaos.com
      Support Request
        "... and is always 0..."
        As it should always be
        David Anastácio // Accenture Song - VFX
        https://www.accenture.com/us-en/serv...visual-effects
          This is a good design decision. It was always annoying having to remember to offset the shutter interval in VRay.
