Houdini crashes, if edits are made in the component builder
  • Houdini crashes, if edits are made in the component builder
    if I use the component builder and I am trying to make edtis in a shader (vray shader, principal shader, does not matter), while running the vray viewport renderer, houdini crashes.
    if I do not use the compoent builder it works as expected ... I can interactivly change the shader (and lights and stuff )
    I can work around it easily, by doing the lookdev outside of the component builder setup. Cheers Christian
Name:	Screenshot 2022-11-25 112452.png
    Dear bumba, hello.
    Excuse us for the delayed response!
    Please download and install our V-Ray 6 release build from here.
    It is fixed, I have just tested it.
    TS
    Tsvetomira Girginova | chaos.com
    3D Support (AEC,HOU,C4D) Team Lead | contact us
      Hi Tsvetomira,
      Thx. I am still on Vray 5. Are the fixes also transfered to the older vray version or do I need to upgrade as soon as possible?
      (Is Vray 6 prioritized over Vray 5?)
      I am using the nightlies, I am in production right now and I have a few months ahead of me.
      THX in advance and cheers.
        The Houdini scene translator is exactly the same in V-Ray 5 and V-Ray 6 builds, only the V-Ray core is different (and the newer features exposed in 6.x of course).
        So you could use 5.x nightly / stable-nightly build.
        andrei.izrantcev@chaos.com
        Support Request
          THX Andrei perfect
