[HOU-3613] Volumegrid RGB field binding
  • [HOU-3613] Volumegrid RGB field binding
    Hello,
    I'm trying to work with the volumegrid shader to use a Cd field as the smoke color, by loading a vdb volume with a "volume" node in LOP, as it doesn't seem to work, I wanted to ask if the "use field as color if the field is 3float" and "remap if the field is a single float" was working under the USD implementation?
    Thanks,
    Marvin
    [EDIT] The field I was trying to use seems to be a vec3 field, which seems to not be supported, I split it into 3 float vector but it still doesn't work
    [EDIT2] Importing the volume in SOP and using a SOPImport, makes the Cd binding works, is it a bug?
    Marvin Chrastek
    Lighting Lead @ Ghost VFX
    Bump, if anyone has any idea on what's going on?
    Best,
    Marvin
    Marvin Chrastek
      Could you please share some .hip file?
      andrei.izrantcev@chaos.com
      Support Request
        Here is the package, I tried to annotate the issues
        https://drive.google.com/file/d/1t0D...usp=share_link
        Marvin Chrastek
          Hey Nevoreko ,
          We have a fix under review; I will hopefully ping you in a couple of days when it's available in the nightly builds.
          Best regards!
          gosho.genchev@chaosgroup.com
            Hey Gosho.Genchev,
            Thanks for the update!
            Yes let me know whenever there is something new about this issue, thanks
            Marvin
            Marvin Chrastek
