Error using v-ray transform matrix with vray 6
  • Error using v-ray transform matrix with vray 6
    I'm getting the following when I hook up a transform matrix to a shader graph. I have a simple spherical projection set up. When I try to transform that projection using the V-Ray Transform Matrix, it throws the error below. I've attached a simple hip as well.
    We're using Houdini 19.5.435 and V-Ray 6.00.21 [d833c431] from 9 Feb 2023​
    Thanks,
    Chris
    Code:
    Traceback (most recent call last):
    File "<stdin>", line 8, in <module>
    File "Q:/appInstalls/vray/6.00.21_d63831a/houdini/19.5.435/vfh_home/husdplugins\shadertranslatorsfh_usd.py", line 1307, in createMaterialShader
    helper.createAndConnectUsdTerminalShader(shader_no de, shader_type, shader_node_output_name)
    File "Q:/appInstalls/vray/6.00.21_d63831a/houdini/19.5.435/vfh_home/husdplugins\shadertranslatorsfh_usd.py", line 973, in createAndConnectUsdTerminalShader
    SolarisShaderTranslatorHelper.createAndConnectUsdT erminalShader(self,
    File "C:\PROGRA~1/SIDEEF~1/HOUDIN~1.435/houdini/python3.9libs\husd\shadertranslator.py", line 891, in createAndConnectUsdTerminalShader
    usd_shader_output_path = self.createUsdTerminalShader(
    File "C:\PROGRA~1/SIDEEF~1/HOUDIN~1.435/houdini/python3.9libs\husd\shadertranslator.py", line 915, in createUsdTerminalShader
    return self.createUsdShaderChain(
    File "Q:/appInstalls/vray/6.00.21_d63831a/houdini/19.5.435/vfh_home/husdplugins\shadertranslatorsfh_usd.py", line 828, in createUsdShaderChain
    self.createAndConnectUsdInputShader( usd_shader_to_connect_to,
    File "C:\PROGRA~1/SIDEEF~1/HOUDIN~1.435/houdini/python3.9libs\husd\shadertranslator.py", line 1092, in createAndConnectUsdInputShader
    self.createUsdShaderWithTranslator(
    File "C:\PROGRA~1/SIDEEF~1/HOUDIN~1.435/houdini/python3.9libs\husd\shadertranslator.py", line 1123, in createUsdShaderWithTranslator
    return self.createUsdShaderWithThisTranslator(
    File "C:\PROGRA~1/SIDEEF~1/HOUDIN~1.435/houdini/python3.9libs\husd\shadertranslator.py", line 1135, in createUsdShaderWithThisTranslator
    return self.createUsdShaderChain( shader_node, shader_node_output_name,
    File "Q:/appInstalls/vray/6.00.21_d63831a/houdini/19.5.435/vfh_home/husdplugins\shadertranslatorsfh_usd.py", line 697, in createUsdShaderChain
    (usd_shader, inputs_to_follow ) = self.hdkCreateUsdShaderOrGraph(
    File "Q:/appInstalls/vray/6.00.21_d63831a/houdini/19.5.435/vfh_home/husdplugins\shadertranslatorsfh_usd.py", line 652, in hdkCreateUsdShaderOrGraph
    return self.createUsdShaderOrGraph(shader_node, shader_node_output_name, usd_parent_schema, usd_shader_prim_name)
    File "C:\PROGRA~1/SIDEEF~1/HOUDIN~1.435/houdini/python3.9libs\husd\shadertranslator.py", line 1169, in createUsdShaderOrGraph
    usd_schema = self.createUsdShader(
    File "C:\PROGRA~1/SIDEEF~1/HOUDIN~1.435/houdini/python3.9libs\husd\shadertranslator.py", line 1399, in createUsdShader
    self.createUsdShaderInputAttributes( usd_shader, shader_node )
    File "Q:/appInstalls/vray/6.00.21_d63831a/houdini/19.5.435/vfh_home/husdplugins\shadertranslatorsfh_usd.py", line 1188, in createUsdShaderInputAttributes
    self.createVRayNodeMetaImageFile(usd_shader, shader_node, shader_node_parameter_names)
    File "Q:/appInstalls/vray/6.00.21_d63831a/houdini/19.5.435/vfh_home/husdplugins\shadertranslatorsfh_usd.py", line 1160, in createVRayNodeMetaImageFile
    con_uvwgen_output = self.createUsdShaderChain(con_uvwgen_node, "uvwgen", parent)
    File "Q:/appInstalls/vray/6.00.21_d63831a/houdini/19.5.435/vfh_home/husdplugins\shadertranslatorsfh_usd.py", line 1201, in createUsdShaderInputAttributes
    con_usd_shader_path = self.usdShaderPrimitivePath(con_node, parent)
    TypeError: usdShaderPrimitivePath() missing 1 required positional argument: 'usd_shader_prim_name'
    Thanks!
    Will work fine in the next nightly/stable.
    andrei.izrantcev@chaos.com
    Support Request
      Thank you!
