Rendervars contains alpha
  • Rendervars contains alpha
    Hello,
    Using V-Ray 6.1.09 build 22528 in Houdini 19.5.605
    I noticed that the vraystandardrendervars node were generating color4f render-elements, ending up with all the render-elements containing an alpha channel, in standalone/maya it seems that the default is to be color3f with no alpha, would it be possible to have this behavior by default to have it match? Or is this on purpose maybe?
    Thanks,
    Marvin
    Marvin Chrastek
    Lighting Lead @ Ghost VFX
    Little bump! We can obviously edit all the rendervars manually to get back the behavior, but I would like to know if this is intended first, and if it's not then maybe it needs a fix
    Thanks,
    Marvin
    Marvin Chrastek
      Yes, it's intended.
      andrei.izrantcev@chaos.com
      Support Request
        Alright, thank you!
        Marvin Chrastek
