Low Cpu Usage in arm64 Build.
  • Low Cpu Usage in arm64 Build.
    Hi
    I have just tested out my new M3 Max MacBook Pro. Using the latest available nightly vray_adv_61009_houdini20.0_98cab92_22610_install_m ac_arm64.zip 13 Dec 02:18
    I'm seeing low CPU usage. It's only using about 50% of the high-performance cores. There is also a strange behaviour if you enable Karma and switch back to VRay. VRay then only uses the efficiency cores.
    Here is a quick video showing what I'm seeing.
    https://www.dropbox.com/scl/fi/59l6j...b1zcq80g9&dl=0
    David.​
    www.lunaranimation.com
