Bake UDIMs
  • Bake UDIMs
    Hello,
    Does the "Texture Baking" on the "Bake"-tab of the VRay Render-Settings in Solaris support UDIMS? If so, how does one set it up? It's a very minimal UI and I see no mention of it.
    Thanks,
    Dan
    It actually exposes all available BakeView plugin settings.
    Use U min/max, V min/max to specify the UDIM tile you need to bake.
    Animate settings if needed to bake multiple tiles.
    andrei.izrantcev@chaos.com
    Support Request
      Do you have a simple setup? I'm struggling
      Richard Blank
      www.haymakerfx.com
        I got it to work pretty good. I have tiles going from 1001 to 1091, just straight up. So to get the udim to the corresponding V min and V max you can write for Vmin ($F-1001)/10 and for Vmax ($F-1001)/10+1. Then just render the frames 1001 to 1091 with 10 increment and you don't have to rename the files.
        Richard Blank
        www.haymakerfx.com
