(Open) [HOU-4489] Husk: VRay progress update increments
  • (Open) [HOU-4489] Husk: VRay progress update increments
    Is there a way to adjust the update frequency of the render logs when using Husk and VRay?
    We are using this command to kick off the render: houdini/20.0.724/bin/husk -f 1004 --renderer V-Ray -Va2
    This is what we are currently seeing:
    [ 2024-11-06 12:38:18 ] : [ Mem : 116.84 GB ] : [2024/Nov/06|12:38:16] [info] V-Ray: Rendering image... 54%
    [ 2024-11-06 12:38:18 ] : [ Mem : 116.84 GB ] : [2024/Nov/06|12:38:17] [info] V-Ray: Rendering image... 54%
    [ 2024-11-06 12:38:18 ] : [ Mem : 116.84 GB ] : [2024/Nov/06|12:38:17] [info] V-Ray: Rendering image... 55%
    [ 2024-11-06 12:38:18 ] : [ Mem : 116.84 GB ] : [2024/Nov/06|12:38:18] [info] V-Ray: Rendering image... 55%
    [ 2024-11-06 12:38:18 ] : [ Mem : 116.84 GB ] : [2024/Nov/06|12:38:18] [info] V-Ray: Rendering image... 56%​
    Jacob Børsting
    Head of Pipeline @ Ghost VFX
    Bump. These ultra-granular progress updates make for endless scrolling when trying to debug or locate particular info. Any pointers as to where we can control this are most welcome..
      Hello,
      We'll change the behavior to update for each % change in progress during rendering instead of updating at a set time interval. I hope that will help out with the clutter.
      Best regards!
      gosho.genchev@chaosgroup.com
        Thanks Gosho.Genchev , I think that would work better. Will there be any way for the user to configure the progress interval (via UI, env var or otherwise), or will it be a hardcoded value?
          Hey Dan Andersen ,
          We decided on hard-coding it to 1% intervals to avoid cluttering the UI. Do you see the need of exposing such a control?
          Best regards!
            I think it's a sensible default, so we're probably fine without the ability to change it. If it turns out to be an issue, I'll make a new forum post
