Nightly build naming
  • Nightly build naming
    Would be great if you could rename the nightly builds a little.
    Currently they are named as for example:
    vray_adv_41203_houdini17.5.293_383fae7_4915_window s.zip
    It would be great if we could remove the "4915" part as it appears to be random/unique for each package. Makes it harder to script the unpackage and environment setup.
    -- Erik
    This is not a random number, it's a build number and it is more easy to track the issues by build number, instead of the hash "383fae7". Every time VFH is build this number is increased by 1.
    Georgy Chakarov | QA
    www.chaosgroup.com
    georgy.chakarov@chaosgroup.com
      I see. Guess I'll have to add some directory name wrangling.
      -- Erik
        It would be helpful if this number would also appear in the console entry at start-up. Currently it shows only the hash.
        Like: VFH [Info] * Build 724e01b from 26 Aug 2019 04:17
        Is there also any way to figure out the Build Number in a already running Houdini? Something like an "About V-Ray" button?
        Aleksej Skrypnik | FX Artist | unexpected
          You could use Python:
          Code:
          >>> import _vfh_ipr
          >>> _vfh_ipr.getVfhHash()
          'f62c84b2'
          >>> _vfh_ipr.getVRayVersion()
          (4, 12, 3)
          >>> _vfh_ipr.getVRayHash()
          'fddb2d28'
          andrei.izrantcev@chaos.com
          Support Request
            Is there a documentation of the commands?
            I'd like to get the build as number.
            vray_adv_41203_houdini17.5.293_383fae7_4915_windows.zip
            The 4915 in this case.
              There is no documentation for that now and I haven't added build number access api yet.
              You could use Python's dir():
              Code:
              >>> import _vfh_ipr
              >>> dir(_vfh_ipr)
              ['__doc__', '__file__', '__name__', '__package__', 'deleteOpNode', 'exportOpNode', 'expo
              rtView', 'getMaterials', 'getOpList', 'getVRayHash', 'getVRayVersion', 'getVRayVersionSt
              ring', 'getVfhHash', 'init', 'isFatalError', 'isRopGPU', 'isRopValid', 'logClearCollecte
              d', 'logGetErrors', 'logGetWarnings', 'logMessage', 'logPrint', 'logSetCollect', 'render
              IPR', 'syncScene', 'transferAutoCorrections']
              Just note that all those commands (except version methods) are not supposed to be used by the end-users.
              Support Request
