I'm currently importing in houdini a lot of Object from Quixel Bridge and i loose a lot of time to create new vray material and goind to search all textures and setup all materials.
Having a convert scene to Vray like we have in 3DSMAX help a lot.
How can we build a converter from mantra materials to Vray materials ?
GHiOM = Guillaume Gaillard
freelance 3D artist www.ghiom.com
I'll try messaging the Quixel guys to check if they can do something about supporting V-Ray with the bridge in Houdini.
As to the Mantra materials in general - that is possible and should not be that hard to do - the results, however, will likely be vastly different in case the setup is more complicated than just a few textures and a shader. I'm logging it and we'll see what can be done about this.
Export vrscene file from 3dsmax and load it with VRayScene SOP.
Regarding material conversion from Mantra - there are no plans implementing this for now.
