Using reference objects and rest attribut works perfect for native geometry and packed primities but not for alembics. Is this something that can get fixed?
For extra info I use the sampler node with pointReference connected to an extraTex in the renderchannels.
also a small note:
If you select an object from the menu in this example an object called pRef it wont work, the whole path has to be written as in /obj/pRef.
also a small note:
