missing inputs on triplanar node
  • missing inputs on triplanar node
    hi, we're missing some inputs to the triplanar node. specifically Scale, blend, frame offset and texture rotation
    Regards Alexis
    http://goodbyekansasstudios.com/
    Hm, indeed the Scale input is missing and we'll expose it, however the blend/frame offset/rotation are not map-able - exposing them as inputs is probably a mistake (in case you are comparing to Maya). If you plan to drive them using geometry attributes, I'm afraid that won't work.
    All the best!
    gosho.genchev@chaosgroup.com
      thanks alot! scale was the one we needed
