I'll log it as an improvement - for the time being you can add the properties to a regular node, open the parameter interface, copy the V-Ray folder and paste it under the OTL->Edit Parameter Interface->root.
In the latest nightly I've removed all the type checks so you should be able to add properties to any object... Could you pls check if this works for you?
