Scripting control of VRay Frame Buffer OCIO settings
  • Scripting control of VRay Frame Buffer OCIO settings
    In maya we have access to the vfbControl command and use it to setup things such as ocioinputcolorspace, ociodisplaydevice and ocioviewtransform.
    What would be the workflow to do this in Houdini? Environment variables would work as well.
    -- Erik
    This is not implemented.
    At which stage do u want to modify those? Pre-render? Pre-frame? On scene load?
    andrei.izrantcev@chaos.com
    Support Request
      Just to expand on Andre's post - there are environment variables you can use for the Frame Buffer - attached below is an image showing the variables you're looking for. Seem to work on my end - please ping us if you hit any issues.
      Cheers!
      gosho.genchev@chaosgroup.com
        Found these as well and it works for us.
        -- Erik
