(Resolved) physical cam settings on HDA
  • (Resolved) physical cam settings on HDA
    What we want:
    to be able to add physical cam properties to a hda containing a camera and the repsentative node is the camera inside
    why:
    In our pipeline we have a camera asset which is an hda which containg camera and other settings. We dont want to unlock the tool to apply the physical camera properties because it would break if the asset gets updated.
    Question:
    Is this possible to do?
    Click image for larger version  Name:	cam2.png Views:	113 Size:	3.2 KB ID:	1116128Click image for larger version  Name:	cam1.png Views:	82 Size:	15.9 KB ID:	1116129Click image for larger version  Name:	cam3.png Views:	76 Size:	6.0 KB ID:	1116130
    http://goodbyekansasstudios.com/
    Yes, that's doable.
    Question: could camera be nested in this hda in some subnet?
    Basically, I could just check all camera parent networks for physical settings...
    andrei.izrantcev@chaos.com
    Support Request
      yes, check parent network would be great!
        Originally posted by LeoYfver View Post
        What we want:
        why:
        Question:
        Hi Leo,
        We do the same, we also have a camera HDA but instead it already comes with the vray camera properties in it. The camera inside the HDA already has the camera properties applied to it and the top level HDA just has the options to activate/deactivate them and control its settings. This way you don't need to apply the settings to the HDA node or unlock it to apply to the camera.
        Best,
        David.
        David Anastácio // Accenture Song - VFX
        https://www.accenture.com/us-en/serv...visual-effects
          david.anastacio We discussed that too and its a possibility. I didnt really want to make our rendercamera tool having software specific settings so I thought this approach was better and artists could just add the physical camera properties when necessary. If it breaks your workflow with it checking parent hierarchies we could skip this feature.
          Regards Alexis
            Regards Alexis
            Hi Alexis,
            I don't see why it would break, so it should not be an issue and then both approaches are supported.
            Best,
            David.
              david.anastacio Sounds good
              bdancer Do you think you will implement that? i guess it also needs to be possible to add the physical camera properties to subnet and HDA:s also
                Should be in the nightly already.
                Support Request
