Phoenix FD for Maya beta 3
  • Phoenix FD for Maya beta 3
    Hello everybody,
    The new beta is on the site. Here is the changelog:
    Phoenix FD 2.0 beta 3 (April 6, 2012)
    [bug] Crash with PhoenixFD force without a simulator during the simulation
    [bug] Simulators with preview turned off not rendered properly during the simulation
    [bug] Double emission contribution with additional lights and GI
    [bug] Transforms for PhoenixFD nodes must be named accordingly
    [bug] Error saving scenes in binary format with Phoenix nodes in Maya 2011 and prior
    [bug] Visible seams with wrapped containers
    [bug] Intermediate objects interact with the simulation
    [bug] Crash with foam simulation in some rare cases
    [bug] Instance rendering is not working immediately after duplicating
    [new feature] Solid mode rendering to work with the RT engine
    [new feature] Fire/Smoke rendering to work with the RT engine
    [new feature] Custom gravity vector
    [new feature] PhoenixFD menu in Dynamics
    [new feature] Ability to "reset" the simulation (stop/clear cache/revert)
    [new feature] Auto mapping option for PhoenixFD 3D texture
    Phoenix FD 2.0 beta 2 (March 14, 2012)
    [bug] Crash when saving a preview in solid geometry mode
    [bug] Crash with additional lights and transparency/emission that use a texture
    [bug] Emission texture modulation checkbox is not working
    [bug] Emission component do not render with the stand-alone and DR
    [bug] Crash with Turbulence preview when tweaked while simulation is running
    [bug] Crash in animation mode
    [bug] Phoenix utility nodes can be selected only when clicked on the wireframe
    [bug] Wrong shading color of the Phoenix source in the viewport under VMWare Player
    [bug] Crash when closing Maya after rendering a scene with foam
    [modified feature] Support more then one light in the GPU preview
    [modified feature] Boundary conditions must show X/Y/Z related to the Maya viewport, not the simulator core
    [modified feature] DAG processing optimization when the interaction set is inclusive
    [modified feature] Phoenix textures - detect circular references
    [modified feature] Native Python scripting
    [modified feature] Stopping the simulation must revert the frame to the last simulated result
    [new feature] Support for vray lights with the gpu shading
    [new feature] Support for flipping Y and Z axis when reading a cache file
    [feature request] PhoenixFD installation must not change the PYTHONPATH environment variable
    [feature request] PhoenixFD must delete its shelf when the plugin is unloaded
    Here are some known issues:
    • RT is only partially supported in the official versions of V-Ray for Maya. To get the full featured RT support, you need a recent nightly build, but it's not obligatory. Soon, there will be a stable version of V-Ray for Maya that fully supports Phoenix FD. The known limitations of the current official V-Ray for Maya are:
      - can't update when the simulator parameters or time is changed (camera changing is working though)
      - works only in geometry mode (this is in Rendering/V-Ray section in AE). Geometry mode for fire/smoke is not recomended for the production render though, unless heat haze must be used.
    • While simulating, DR is working currently at random. If you are experiencing such problems, try pausing the simulation.
    • Some antivirus programs (like Microsoft Security Essentials) that have real time protection may cause the simulation to run a couple of times slower. They seem to check the files generated by Phoenix FD.
    • For simulation it's better to have a processor with a higher clock speed, then with more cores.
    V-Ray/PhoenixFD for Maya developer
    When the multi-byte character is being used for the scene name of Maya, or output path of Phoenix FD, simulation data is not loaded at the time of RT session.
    -----vray.exe message----------
    warning: [PhoenixSimPlugin] Error loading simulation data for time 24
    tests in nightly 22501 + Phoenix FD 2.0 beta 3 (April 6)
    OakCorp Japan - Yuji Yamauchi
    oakcorp.net
    v-ray.jp
