Substance IOR maps vs. V-ray
  • Substance IOR maps vs. V-ray
    Hi Guys,
    Quick question. I noticed Substance painter outputs a greyscale map with values ranging from 0 to 1 and this needs to be plugged into v-ray's 'fresnel ior'. I am used to working with ranges above 1, so this map is kind of confusing. I noticed it looks good in render though. Theory I have is that the substance ior map is an inverted representation of what I am used to working with. Darker values result in higher IOR and lighter values result in lower IOR. The values are super unclear to me and documentation ignores everything. Can anyone explain?
    Thanks
    Yes, afaik it's 1 / map value for the actual IOR.
    Rens Heeren
    Generalist
    WEBSITE - IMDB - LINKEDIN - OSL SHADERS
      Ah great, thanks! How did you find this out?
        At some point I wrote a substance to vray converter in OSL. : )
        Rens Heeren
        Generalist
          Thanks Rens. Noted and bookmarked.
          always curious...
