Possible to write just Maps out from a Vray-Shading network?
  • Possible to write just Maps out from a Vray-Shading network?
    a special question:
    I have made a scene, in which 2 additional normal maps are added on a VrayMtl through 2 more VrayBumpMtl.
    Now I looking for a way, to adjust it in other software:
    How I can just export the finally composited Normal-Map out, without rendering?
    It would be in generell interesting for any kind of map, to be able to get the composited map.
    In Maya was a function "Hypershade > Edit > Convert to File Texture (Maya Software)"
    but this seems not to support Vray-networks (at least it didn't do anything else than just freezing Maya2018.5)
    You could add a bumpNormals render element.
    Then in the render settings, go to the common tab and under Baking Engine Settings select Texture baking.
    Then select your object and just start a render. You'll need to adjust your resolution to a 1:1 ratio.
    This will not produce the same result once the texture is loaded, though, as this will 'flatten' what has previously been 'layered' in a way. But it's a way to bake the result to a texture and reuse it.
    Alex Yolov
    Product Manager
    V-Ray for Maya, Chaos Player
    www.chaos.com
