VRay 3.6/Maya - Correct way to get alphas when using the dome light (with a transparent object)?
  • VRay 3.6/Maya - Correct way to get alphas when using the dome light (with a transparent object)?
    Hey guys - I'm sure this is simple and I've searched but haven't *quite* found the solution.
    I'm using the Dome Light and an HDRI map to light a clear acrylic plastic trophy.
    Looks great until I realize I can't get an alpha channel.
    If I go to the dome light and uncheck alpha it gets me an alpha around the object, but not for any of it's transparency.
    If I go to the material and check "color + alpha" under the reflection options, it gets me closer. But it doens't feel quite right.
    I'm fairly novice when it comes to VRay so I'm sure i'm just overlooking it. I just figure when I make my object transparent it will automatically apply to the alpha. Not so apparently!
    set the dome light to invisible (under options)? Is that what you are after?
    e: info@adriandenne.com
    w: www.adriandenne.com
      Thanks for the reply, but nope. And I actually had that in an earlier draft of my message but apparently left it out, doh!
      If I do that, it just basically turns off the dome light and still blocks/fills the whole alpha.
        you mentioned you changed reflection to color and alpha, did you change the refraction to all channels?
