Framebuffer zoom broken with tablet in vray next - update 1
  • Framebuffer zoom broken with tablet in vray next - update 1
    Hi
    I just installed Vray next update 1 for Maya 2018.5 on win10
    Zooming in the framebuffer with ctrl + LMB/RMB is broken, mousewheel still works but I prefer working with a pen, and that does not have a wheel
    Kind regards
    David
    David Lessél
    That's odd, as I don't think we've changed anything. Did it work with the initial V-Ray Next release?
    We'll have to test it here.
    Alex Yolov
    Product Manager
    V-Ray for Maya, Chaos Player
    www.chaos.com
      It works fine on our end. We tested 2018.5 on win 10, as well as 2018.4 with Next, and Next, Update 1 and it works here. Can you check if there were some automatic updates to the tablet driver or something else that might have silently fiddled with your setup? You could also try reverting back to the Next version - that will help us determine if it's something on our end, although we didn't make any changes there.
      Alex Yolov
      Product Manager
      www.chaos.com
        Yes it worked with the initial release and the last release, hotfix 2 I think... We are running Vray as a shared network install and all workstations are affected, dont know if this might be causing problems? but it worked fine in the past.
        David Lessél
          Does it still work if you launch an older build on a machine where it currently doesn't work?
          Alex Yolov
          Product Manager
          www.chaos.com
