V-Ray equivalent of Arnold SSS set name
  • V-Ray equivalent of Arnold SSS set name
    I'm new on V-Ray and on this forum.
    I would to know if V-Ray can calculate the SSS of two separate objects like it is just one.
    I came from Arnold and the attribute name for that is "SSS set name".
    Thank you.
    Ed
    If you add V-Ray object properties to your object, there is an attribute called "SSS Surface ID", which can be used for a similar purpose. More details are available here:
    https://docs.chaosgroup.com/display/...jectProperties
    This can also be done with a V-Ray user attribute on the shape; it must be named "VRay_SSS_SurfaceID".
      Hello Vlado,
      Perfect. Thank you very much for this answer.
      Ed
        Just a related question: Which is currently the recommended SSS shader for Vray? The last I heard was "AiSurface"
        thanks...
