Get poly number with VRay smooth of an asset/scene
  • Get poly number with VRay smooth of an asset/scene
    Hello,
    I would to know how I can get the info of the poly number of an asset (or of the full scene) after the VRay rendered smooth.
    I need to send it in exr metadata after.
    Thank you,
    Ed
    You can do that by using this Post Translate Python Script, which will write the polycount for the selected objects. This way you have a choice to either select a certain asset or the whole scene:
    from vray.utils import *
    import maya.cmds as cmds
    nodes=findByType("SettingsEXR")
    for node in nodes:
    strValue = 'polyCount={}'.format(cmds.polyEvaluate(face=True) )
    node.set("extra_attributes", strValue)
      Hello Aleksandar,
      Thank you for your answer.
      I'm going to try.
      Ed
