ACES / OCIO Workflow
  • ACES / OCIO Workflow
    Dear Chaosgroup and other Users,
    after studying several ACES/OCIO workflow examples (mainly not for vray) i am complete confused how vray next and maya 2019 are proper setup for the ACES 1.0.3 workflow.
    Maybe someone is willing to write a quick summary how to set it up right. If one uses Arnold everything is much simpler to setup !
    What i have so far:
    Vray isn´t compatible to the maya built in Aces Presets so you have to load it manually this way:
    Then you manually have to load the same config.ocio into the vray framebuffer:
Name:	V-Ray frame buffer - [100% of 640 x 480]-000305.jpg
    Then the headache begins, FileTexture color spaces:
    HDRI: Utility - linear - srgb
    Color Textures: Utility - linear - srgb but only if they are gamma corrected ? Confusing!
    Camera Images / Backplates: Utility-Rec.709-Camera
    Depth/Roughness/Normalmaps ... Utility - RAW
    Right ? Not sure!
    What else i am missing ?
    And this is more a maya related question, if i use OCIO configuration file i can´t setup rules any more even if i uncheck "Use OCIO Input Color Space Rules". If i create new rule i can´t select an input color space cause it is greyed out:
    So every new filenode gets the colorspace "aces" whatever that means.
    Thanks for any advise in this direction!
    Andy
    The ACES workflow is currently not supported, however, we are working on its implementation. There will be official support for future V-Ray for Maya releases.
      So why there are all the controls for it in the framebuffer ?
        For now, it serves only for previewing purposes. As I already mentioned, we are working on a full implementation for rendering in ACES color space.
          Thanks for your reply. When is the implementation expected ?
            +500 for ACES support.
            https://linktr.ee/cg_oglu
            Ryzen 5950, Geforce 3060, 128GB ram
              Hi hermit.crab
              I can imagine it is difficult to give a concrete timeframe on when ACES will be fully implemented in Vray for Maya. But is it possible to give an indication of how big a task this is? Do you think this will be in one of the upcoming Vray Next for Maya updates? or is it something that is a more major task?
              Also are the plans to run this out through the standard Maya colour management settings(like above?) or will this be a seperate Vray thing?
              This question is becoming quiet critical for my studio as we are having more and more requests to work in UHD (streaming services require 4K UHD for example). So this is very high on our wish list.
              Thanks
              Will
                Originally posted by LL_Will_J View Post
                Hi hermit.crab
                Thanks
                Will
                ACES support is already working internally. After a bit more testing, we plan to implement it in the builds and possibly release it with the next official release.
                  Ow wow! this is great news. Looking forward to seeing how much it adds to the look of our renders.
                  Regards
                  Will
                    Hey, I wanted to switch to ACEScg workflow, and followed the instructions, but all my "old" rules where deleted after the OCIO environment variable was set. The issue is the same here like rcm_andi has years ago.
                    The doc is not as detailed as it could. When I use the OCIO configuration, all texture got the ACEScg input colorspace, but in the doc it was recommended to set normal, displ. etc. to RAW. But all add rules buttons are grey and off.
                    The really bad hing is, that all "old" rules were deleted. What is now the correct way? I saw a tutorial for 3dsMax vray 5, but I´really confuse now.
                    Shall I disable the OCIO configuration environment variable? And just add rules for normal, bump, displ, roughness? Shall I set default rules to ACEScg or ACES2065-1 (which was set automaticaly).
                    THX for help guys
