Vray Mud Material
  • Vray Mud Material
    Anyone have a good suggestion on how to build a material that resembles mud? Yes, mud my people. A client wants me to dirty up some models i have done for them. Trying to achieve something like this would be great.
    It's more texturing and displacing than shader work. The shader would be pretty simple, just a mud colored diffuse with some reflection to make it look wet and a noisy bump map to make it feel gritty.
    I've done mud on vehicles before, use a mask to blend between your base material and the mud material on top. And then use a displacement map to displace the thicker areas of the mud, like right behind the tires.
    Depending on what you're trying to muddy up, you may or may not be able to get away with a procedural material for the mud mask. More than likely you'll have to hand paint the mask and the displacement map.
    www.DanielBuck.net - www.My46Willys.com - www.33Chevy.net - www.DNSFail.com
      Buck,
      Thanks for the heads up. Going to give this a go and see what comes of it. Hopefully it works out well.
        I am looking forward to see the results!
        My Artstation
        Whether it is an advantageous position or a disadvantageous one, the opposite state should be always present to your mind. -
        Sun Tsu
          There are good Quixel materials for mud.
          https://quixel.com/assets/sjzjejua
          https://linktr.ee/cg_oglu
          Ryzen 5950, Geforce 3060, 128GB ram
            also a bunch of neat mud and dirt on textures.com that could come in handy
            https://www.textures.com/browse/3d-s...548#ground-mud
            https://www.textures.com/browse/3d-scans/114548#sand
            __
            https://surfaceimperfections.com/
              Love the community here. Thanks guys, going to start looking at these.
